I have a 12VDC cuircuit board with a blown glass fuse (careless wrong polarity). The bands are brown, blue, red plus a wide blue band. Looking at the chart it says the time/current rating is T. Is this a quickblow fuse?
5
T is for slow blow, F for fast, FF for very fast.
  • \$\begingroup\$ (I "knew" explications different from Timed & Fast.) \$\endgroup\$
    – greybeard
    Commented Apr 26 at 11:55
    \$\begingroup\$ I thought 'FF' was just a gag of yours, for "?*%£in' fast", but a search shows it's a real one :-) Upvoted. \$\endgroup\$
    – TonyM
    Commented Apr 26 at 13:26
    \$\begingroup\$ I really wonder where the letters have their origin... German electricians know them as "Träge" and "Flink". \$\endgroup\$
    – asdfex
    Commented Apr 26 at 13:28
  • T = Time-lag.
  • F = Fast.
See more here: What fuse can I use to replace this old glass tube fuse?
If you don't have the datasheet: T or "Time-Delay" is generally used for slow fuses.
If you have the part type, it is better to check the datasheet.
