I want to simulate a DCDC buck converter to go from 6V to 3.3V, with a max. output current of 100mA.
I'm using this buck converter online calculator to find out the values I need. This is the results I obtain:
It doesn't mention the capacitor I need, but it does calculate the required inductor and duty cycle.
I have plugged these values into a CircuitLab buck converter example, but I don't obtain the desired output:
You can simulate the circuit here.
What do I need to do to achieve an output of 100mA @ 3.3V? (I'm not concerned about the ripple at this point)
