Oscillation on an 4 phase 12 to 24V 20A boost inverter
I’m using 2 pieces of LTC3787 to make a 12-24V inverter. I made a 4 layer board from it to have enough ground to make sure all will be stabile. But I have big oscillation on my output. With no load it’s ok. But with a few mA of load the trouble starts. I try to adjust the ITH RC values and tried only the master and the slave unit apart and tried connect my ground on different locations, canceled the 10pf caps on the voltage divider . So fare nothing worked out.
Hope some one can help me in were to look for to solve this issue schematic:
[1]
[1]
VGS low side FET
[2]
VGS low side FET voltage
[3]
Input current - output ocsilation with 60mA load
yellow = current is 100mV/1A so top is about 75A spikes on the 12V input with 60mA load on the 24V side. blue is the output voltage rimple
[4]
ITH signal voltage - input current on the board 100mv/1A (about 75A)
[5]
input current yellow 100mV/1A- vgs lowside FET voltage
already thanks for all the help!!
