In this circuit, the switch has been open for a long time that is the 2F capacitance is full. Now we close the switch. What is the equation of the current and voltage of the 2F capacitance after closing the switch?
Here is my solution which I think is wrong:
$$ 3\frac{dv}{dt} + v = 2 $$
$$ 3\frac{dv}{dt} + v = 0 \\ v = ae^{bt} \\ 3b + 1 = 0 \\ b = \frac{-1}{3} \\ v = ae^{\frac{-1}{3}t} + 2 $$
in t = 0 V should be 2 : $$ a + 2 = 2 \\ a = 0 $$
Which means that V will be constant after closing the switch and no current will pass through the 1F or 2F capacitance, which is wrong.
