This exercise is really good because it covers a lot of material in a seemingly simple question. Most of the work you did is good (except getting the sign of e wrong), but you missed a key aspect, as you'll see.
Forgive me for redrawing the circuit with some extra labels, because it's going to make things a lot easier to refer to later.
When I write \$V_{OUT}\$, I am referring to the the potential at node "OUT", relative to ground (0V). The potential at node "P" is \$V_P\$, and so on. The voltage across R1 will be \$V_{R1}\$, the voltage across R2 is \$V_{R2}\$ and so on. Given that \$V_{C1} = V_{OUT} - 0V = V_{OUT} \$, I'm just going to say \$V_{OUT}\$ instead of refering to the voltage across C1. Currents through components will be labelled \$I_{R1}\$, \$I_{R3}\$ etc.
By the way, usually we don't refer to the opamp's inputs as "positive" and "negative", because there's room for confusion between those inputs and its supply terminals. The proper terms are "non-inverting" (for the "+" terminal) and "inverting". In my diagram I deliberately chose the node names "P" and "Q" to avoid such ambiguity, and because repeatedly saying "the voltage at the non-inverting input" quickly becomes tedious. Saying "\$V_P\$" is so much easier.
Starting as you did, by finding the state of the system for \$t < 0\$, after having been that way for a long time, since the switch in its open position, node P is connected to ground, and so:
$$ V_P(t<0) = 0V $$
You correctly described the opamp's behaviour. That is, being ideal, and having negative feedback, it will adjust its output \$V_E\$ in such a way as to maintain the condition \$V_Q = V_P\$. You can probably intuitively see that for \$V_Q\$ to be the same as \$V_P = 0V\$, the only way that can be true is if \$V_E = 0V\$ also. However, following your lead, I'll formally derive \$V_E\$:
$$ V_Q = V_P = 0V $$
$$ 0V + V_{R2} = V_Q = 0V $$
$$ V_{R2} = 0V $$
$$ I_{R2} = \frac{V_{R2}}{R_2} = \frac{0V}{R_2} = 0A $$
Find \$V_E\$:
$$ I_{R1} = I_{R2} = \frac{V_E}{R_1 + R_2} $$
$$\begin{aligned}
V_E &= I_{R2} \times (R_1 + R_2)
\newline \newline
&= 0A \times (R_1 + R_2) = 0V
\end{aligned}$$
The opamp reacts to changes in its output in the following way: If something happens to lower \$V_E\$, such as some load connected to its output, that causes a corresponding drop in \$V_Q\$. The opamp now has a non-zero difference between \$V_Q\$ at its inverting input, and \$V_P\$ at its non-inverting input.
Qualitatively, now \$V_P - V_Q > 0\$, and as you know, the opamp tries to amplifiy this difference (remember \$V_E = A(V_P-V_Q)\$, where A is the opamp's open loop gain.) This causes \$V_E\$ to rise, in opposition to the very perturbation that caused it to drop in the first place. It will continue to pull it's output higher in potential, harder and harder, until it restores equality between \$V_P\$ and \$V_Q\$. The same behaviour also prevents \$V_E\$ from rising.
In this way, the opamp is able to maintain its output \$V_E\$ at whatever voltage is necessary to keep \$V_P - V_Q = 0V\$, or \$V_P = V_Q\$. Crucially, the relationship between \$V_E\$, \$V_Q\$, \$V_P\$, \$R_1\$ and \$R_2\$ (that we derived above) is independent of any load connected to the opamp's output. You don't see C1 or R3 in those equations at all. This is why we say that an opamp with negative feedback has 0Ω output impedance. You can hang anything you like off that output and (providing it's "strong" enough), it will win any battle over who gets to decide the value of \$V_E\$.
And here's the thing you missed: because of this, the opamp output may be treated as an ideal voltage source, of value \$V_E\$, dependent only upon \$V_P\$. As \$V_P\$ changes, \$V_E\$ changes accordingly (as defined by feedback), but nothing else, absolutely nothing can change \$V_E\$.
In this circuit R3 and C1 do not have any influence over \$V_E\$, and \$V_E\$ may be treated as a stubborn, ideal voltage source. It may as well be a battery, as far as R3 and C2 are concerned, they have no way of knowing the difference.
Given our derivation for \$V_E(t<0)\$ above, you may confidently state that \$V_E\$ will be zero volts, regardless of what's connected to it. And the same goes for \$V_E(t \ge 0)\$, as we'll derive now.
When the switch is closed at tiem \$t=0\$, node P is connected to the voltage source V1:
$$ V_P(t \ge 0) = V_S = +6V $$
The same rules and equations apply for this new condition, when finding \$V_E\$:
$$\begin{aligned}
V_Q &= V_P = 6V
\newline \newline
I_{R2} &= \frac{V_Q}{R_2}
\newline \newline
&= \frac{6V}{10k\Omega}
\newline \newline
&= 600 \mu A
\newline \newline
\newline \newline
&= 600 \mu A \times (10k\Omega + 10k\Omega)
\newline \newline
&= 12V
\end{aligned}$$
As a side note, I am sure you are familiar with this circuit:
Its the ubiquitous non-inverting amplifier, where:
$$ V_{OUT} = V_{IN}(1 + \frac{R1}{R2}) $$
Can you see this "module" is exactly what you have inside your own circuit? Also please be sure to understand the significance of the fact that this formula is completely independent of anything connected at the output. It's true regardless of the load, because of the reasons I outlined above, namely that the opamp has negative feedback, which will cause it to adjust its output in any way necessary to keep its inverting and non-inverting inputs at the same potential, making it able to overcome the influence of any load.
Plugging in our values for \$V_P\$, \$R_1\$ and \$R_2\$:
$$ V_{OUT}(t < 0) = V_{IN}(t < 0) \times (1 + \frac{R_1}{R_2}) = 0V \times (1 + \frac{10k\Omega}{10k\Omega}) = 0V $$
$$ V_{OUT}(t \ge 0) = V_{IN}(t \ge 0) \times (1 + \frac{R_1}{R_2}) = 6V \times (1+ \frac{10k\Omega}{10k\Omega}) = 12V $$
As you can see, both conditions agree with our more rigourous analysis above. I suppose the moral is that you should look for "building blocks" like this in all circuits you intend to analyse, so that you can apply the already-derived, tried-and-true formulae, instead of working it all out from first principles every time.
The last thing to do is "picture" your circuit in the light of the fact that we have two conditions, in both of which the opamp has become a simple voltage source, of 0V (before the switch was closed) and 12V (after):
In the left (t < 0) version, there's no voltage source, since a zero volt source is effectively a direct connection to ground. I'll leave it up to you now to complete the exercise, which is to "prove" the value of \$V_{OUT}\$ at times \$t = 0\$ and \$t \gg 0\$.
