I need to find the transfer function of two RC circuits connected together.
Here is how I tried solving it, using maple, the two equations for nodal tensions are found at (1) as the solve({eq1, eq2}) parameters:
eq1 is the sum of currents at node A, eq2 is the sum of currents at node B.
Well my problem is that I get a result at (3) that is not the answer from the solutions booklet (which is at (4)).
I am quite rusty into solving circuits, could anyone take the time to explain me how to get to the correct answer? I must find the transfer function \$ G(s) = Y_{2}(s)/U_{1}(s) \$. \$ u_{1}(t) \$ is a voltage excitation, and \$ u_{2}(t) \$ is the same voltage as \$ V_{C_{1}}(t) \$.
Thanks!
P.S. If anyone could tell me what I did wrong in nodal analysis it would be great.
