I want to start learning EE with Arduino so as a project I decided to build an Ohmmeter and measure a (specific) resistance that should be about 100 KΩ ±50KΩ.
In order to probe for that resistance I need to feed 1.5V (pulsed) at either 2.5µA, 5µA or 10µA (need a pretty close approximation anyways).
For the 1.5V I could use a 5V PWM pin with a 30% duty cycle.
To get the current I need, I'll add resistors of 600 KΩ (for an output of 2.5µA), 300 KΩ (for 5µA) or 1.5 MΩ respectively (for 10µA).
In order to be able to measure the range 50KΩ - 150KΩ as accurate as possible I know the reference resistor and the measured resistor have to be pretty close to each other.
Would this work?
I'm good with the software programming side but not with putting electric components together so anything more than resistors will hurt my brain :)
Thanks!
