Can a TRIAC be used on the secondary winding of an AC isolation transformer?
Say I have 230 V on the primary, but I want to use the 12 V AC secondary, will a TRIAC work on the secondary?
What I want to achieve is this: Use the TRIAC on a secondary winding (say 12-24 VAC) to use on a spot welder. The control pulse to the gate of the TRIAC will be delivered via two optocouplers (one for the positive cycle and one for the negative cycle) of the AC wave. The optocouplers will be controlled by a single-shot (mono-stable) pulse from a 555.
