I'm trying to write a TDC (Time to Digital Converter) model in Verilog AMS. I'm really new at the AMS part of Verilog.
The problem I'm running into is in assigning the final state of the TDC to the outputs. Below I present the code. I get "Expecting a scalar expression" on the line within the generate.
module TDC_model #(
parameter integer N_delays = 50,
parameter Time_delay = 20p,
parameter Vdd = 1.8 // Positive power supply V
input TDC_Start_i,
input TDC_Stop_i,
// input TDC_CLK_i,
input TDC_Rst_p_i,
output TDC_therm_o
electrical [N_delays - 1: 0] TDC_therm_o;
electrical TDC_Start_i, TDC_Stop_i, TDC_Rst_p_i;
integer i;
real vmid;
real delay_reg[0: N_delays - 1];
real delay_chain[0: N_delays - 1];
analog begin
//Initialize parameters
@(initial_step) begin
vmid=(Vdd)/2.0; // Midrail Voltage
for(i=0; i< N_delays; i=i+1) begin
delay_chain[i] = 0;
end
end
//Delay chain delays propagates the signal
@(timer(0, Time_delay)) begin
for(i=1; i < N_delays; i=i+1) begin
delay_chain[N_delays - i] = delay_chain[N_delays - i-1];
end
delay_chain[0] = V(TDC_Start_i); // Beginning of the delay chain
end
// At Stop threshold crossing, buffer the TDC status
@(cross(V(TDC_Stop_i) - vmid, +1)) begin
delay_reg[i] = (delay_chain[i] >= vmid);
end
end
generate i (50 - 1, 0) begin
V(TDC_therm_o) <+ transition(delay_reg[i],0 , 2p, 2p);
end
end
endmodule
