I bought this adjustable power supply kit and successfully assembled it. I wanted to upgrade the potentiometers to 10 turns so I could have fine control over the current and voltage limits set. Both potentiometers are 10K ohm and I have tested both to make sure they were in that range. For some reason, the output of the board drops somewhere like -0.5V when I try to use the upgraded potentiometers but works fine with the originals. What is causing this?
These are similar to the originals, only without the rear two pins (all i could find)
