Referring to the Infineon ICE2A365 datasheet.
In the datasheet, the thermal resistance from junction to ambient is 90 K/W.
What is K? Is it kelvin or degrees C.
If it is kelvin than changing it to degrees centigrade will be approx -183C/W, which does not make any sense.
8
The only difference between them is the zero value (position of origin). Notice that the difference between any two points is the same on both the scales. So 1°C rise in temperature means 1K rise in temperature.
1 degree C is equivalent to 1 degree K.
See image:
The SI units of thermal resistance are kelvins per watt or the equivalent degrees Celsius per watt (the two are the same since the intervals are equal: Δ1 K = Δ1 °C).
As both answers above are true, they are missing the zero (0) reference points: - For °C (Celsius or "Centigrade") scale the 0 reference point is the freezing temperature of water. The °C value can be either positive or negative as needed. - For °K (Kelvin) scale the 0 reference point is the "absolute zero" temperature as follows: "By international agreement, absolute zero is defined as precisely 0 K on the Kelvin scale, which is a thermodynamic (absolute) temperature scale and –273.15 degrees Celsius on the Celsius scale." The °K value can only be positive.
For both °C and °K scales the difference between any two measured temperatures is exactly the same, for instance 1°C difference = 1°K difference.
I was taught that 1 degree centigrade is an actual temperature and 1 centigrade degree is an increment of one degree. This avoids confusion. J Garrioch.
