We are writing a code using vhdl. Please tell us elaborately how to add the fixed_pkg code into the ieee_proposed library.
The fixed package is probably found here: here. Is this the fixed_pkg code that we have to add?
We are trying to make the following code work:
-- Company:
-- Engineer:
-- Create Date: 08/01/2016 03:49:02 PM
-- Design Name:
-- Module Name: fixed_point1 - Behavioral
-- Project Name:
-- Target Devices:
-- Tool Versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
library ieee_proposed;
use ieee_proposed.fixed_pkg.all;
--use ieee.fixed_pkg.all;
entity fixed_point1 is
Port ( a,b : in STD_LOGIC;
c : in STD_LOGIC;
d : in STD_LOGIC_VECTOR (3 downto 0));
end fixed_point1;
architecture Behavioral of fixed_point1 is
signal example : ufixed (3 downto -4);
begin
example <= "10011100";
end Behavioral;
This code is synthesised properly.However during simulation it is giving some compilation error( 'fixed_pkg' is not compiled in library ieee_proposed [../../../fixed_point1.srcs/sources_1/new/fixed_point1.vhd:26]). Please tell us elaborately how to compile fixed_pkg in ieee_proposed so that the simulation works.
