You need at least two flip-flops to synchronise the signal to the clock. One flip-flop is not reliable.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity Sync is
generic
SYNC_BITS: positive := 3 -- Number of bits in the synchronisation buffer (2 minimum).
port
clock : in std_logic;
input : in std_logic; -- Asynchronous input.
output: out std_logic -- Synchronous output.
end entity;
architecture V1 of Sync is
constant SYNC_BUFFER_MSB: positive := SYNC_BITS - 1;
signal sync_buffer: std_logic_vector(SYNC_BUFFER_MSB downto 0) := (others => '0'); -- N-bit synchronisation buffer (2 bits minimum).
alias sync_input: std_logic is sync_buffer(SYNC_BUFFER_MSB); -- The synchronised input is the MSB of the synchronisation buffer.
begin
assert SYNC_BITS >= 2 report "Need a minimum of 2 bits in the synchronisation buffer.";
process(clock)
begin
if rising_edge(clock) then
sync_buffer <= sync_buffer(SYNC_BUFFER_MSB - 1 downto 0) & input;
end if;
output <= sync_input;
end process;
end architecture;
Metastability
Figures from Digital Design and Computer Architecture by Harris & Harris
Figure 1 – Input changing before, after or during aperture.
Figure 2 – Simple synchroniser.
If the input, D, changes within the aperture (set-up and hold time) around the clock edge, the output, D2, is undetermined (metastable) and will take time to resolve to logic 0 or logic 1.
If the resolution time is less than the clock period minus the set-up time, the input to the second flip-flop will be stable, thus the output will successfully follow the input on the next clock edge.
If the resolution time is greater than the clock period minus the set-up time, the input to the second flip-flop will be between 0 and 1 (metastable) on the clock edge causing, it too, to become metastable:
\$ t_{resolution} > T_{clock} - t_{setup} \$
...so, three flip-flops are needed.
With higher clock frequencies, the ratio of resolution time, \$t_{resolution}\$, to clock period, \$T_{clock}\$, increases, necessitating even more flip-flops to satisfy the following equations:
\$ t_{resolution} < N_{cycles} \times T_{clock} - t_{setup} \$
\$ N_{flipflops} = N_{cycles} + 1 \$
...where \$N_{cycles} >= 1\$ and is the number of clock cycles to wait for resolution, thus giving a minimum of two flip-flops in the synchronisation buffer/chain.
