Here is the datasheet of the TI switcher using in my design http://www.ti.com/lit/ds/symlink/tps54620.pdf
Could you please help to find the full-form of RT in RT resistor? Attached is the relevant screenshot for reference.
Thanks VT
Thanks VT
RT means resistor timer for an Astable Clock with external R or external logic clock for synchronous operation, possibly used for N phase shifted parallel converters or EMI or inductor property purposes.
Assuming that "the full-form of RT" means that you want to determine the value of RT, read Section 8.4.1.
