Short introduction! I've recently built electric skateboard (you can look up the commercial ones) and I want to design/get a wireless charging system for it!
The problem is, it seems the current Qi chargers are not capable enough! I would need ideally 50-150w of power to the battery directly.. These little qi ones are only able to output 2.5-5w max per unit.. + There is also a limit on how many devices the charging mat can sustain it seems (+ their power ratings in general are also not great - Samsung has up to 1amp charging power, it looks)
http://www.bestbuy.com/site/samsung-mini-qi-wireless-charging-pad-black/7250019.p?skuId=7250019
I found a company, which seems to be related to developing wireless technology exlusively, take a look at them:
Search: Proxy module 100w (the 3rd result should be the one!)
They have a product for 100w output but it is rather bulky.. plus, I believe the price could also be quite steep as it is individually produced model/product and they will probably want some hefty honorarium for developing such product with their intelectual property...
Btw - I also found such a chip called: BQ 51050B you can look it up, it is made by texas instruments, it is not possible for me to post any more links for now, so I cannot give datasheet directly.
Anyways the chip is for receiving power only and charging the batteries, so it still needs a coil, for receiving power!
It looks like it is already designed for this application (the chip), but the question still remains:
Where to get the parts (coil, especially) to build more powerful wireless transmission module / system?
Thanks for answers anyways - I hope I can come up with something using this forum / Q * A site :)
BTW the max coil diameter should be in the 150mm range / 5.905 in, as the boards are not typically more wider than 200-220mm (~8-9inch.
I umderstand that the diameter alone does not play part.. but the wire thickness and count.. but diamater still should be taken into consideration, because as I said, the receiver coil shouldnt be much wider than that!
