I'm trying to figure out if the BQ78350R1 has a 0.5mm, 0.6mm or 0.8 mm distance between its pins. I'm staring at the data-sheet but I can't find this information. Thanks for giving me a hand with this.
    \$\begingroup\$ Tried the page before the last? \$\endgroup\$
    – PlasmaHH
    Commented Feb 3, 2017 at 21:46
    \$\begingroup\$ Dang, I'm such a moron! 0.5 mm.Thanks. Could you please add this as an answer so I can mark it as solved? \$\endgroup\$
    – Nactus
    Commented Feb 3, 2017 at 21:57
    \$\begingroup\$ Maybe tag @PlasmaHH so he receives a notification. \$\endgroup\$
    – Wesley Lee
    Commented Feb 4, 2017 at 0:25
  • \$\begingroup\$ That's a good point. @PlasmaHH please use the answer option so I can mark it as solved. Thanks \$\endgroup\$
    – Nactus
    Commented Feb 4, 2017 at 2:29
Have a look at the page before the last, which shows all important measurements of the chip:
