My goal is to create n bit hamming distance circuit but using only xors and adders. I do understand that xor is required to compare two bits, but once I have all comparison results, how I can add them using adders to get the total count.
If the result of XOR is ABCD (four bits) then one approach can be:
A ADD B = S_0,C_0
C_0(S_0 ADD C)= S_1,C_1
C_1(S_1 ADD D)= S_2,C_2
However, if we set all A,B,C,D to 1 then this gives 1000 which is not equal to 4. Can you please let me know which part I am missing in the solution? Thanks
  • \$\begingroup\$ Why with just xors and adders? \$\endgroup\$ Commented Apr 7, 2017 at 22:18
A ADD B = S_0,C_0
If I understand things, you should be using S to be the sum and C to be the carry. I may not be understanding that correctly, though. But if so, then try the following:
$$\begin{align*} \left(A + B\right) \rightarrow \left[S_0,C_0\right] \\\\ \left(C+D\right) \rightarrow \left[S_1,C_1\right] \\\\ \left(S_0+S_1\right) \rightarrow \left[S_2,C_2\right] \\\\ \left(C_0+C_1\right) \rightarrow \left[S_3,C_3\right] \\\\ \left(C_2+C_3\right) \rightarrow \left[S_4,C_4\right] \end{align*}$$
Your answer will be the the binary value: \$S_4 S_3 S_2\$.
This is effectively the following schematic:
So, using \$ABCD=1111\$:
$$\begin{align*} \left(1_A + 1_B\right) \rightarrow \left[0_{S_0},1_{C_0}\right] \\\\ \left(1_C + 1_D\right) \rightarrow \left[0_{S_1},1_{C_1}\right] \\\\ \left(0_{S_0} + 0_{S_1}\right) \rightarrow \left[0_{S_2},0_{C_2}\right] \\\\ \left(1_{C_0} + 1_{C_1}\right) \rightarrow \left[0_{S_3},1_{C_3}\right] \\\\ \left(0_{C_2} + 1_{C_3}\right) \rightarrow \left[1_{S_4},0_{C_4}\right] \end{align*}$$
Your answer is: \$1_{S_4} 0_{S_3} 0_{S_2}\$.
You could use a full adder to reduce this a bit.
Here's a generalized half adder approach:
You may notice how wasteful it can be. But it is easy to visualize the extension. And that seems to be your goal. Try extending it to one more bit, adding in \$X_4\$ and note that you can do some pruning of the tree, then.
This approach handles both odd and even numbers of bits in the Hamming symbol string.
If you want to handle only an even number, you could create two of these "trees," one for the even-numbered input bits and one for the odd-numbered input bits and then sum the results at the end of the two trees with a standard adder arrangement.
  • \$\begingroup\$ Thanks for the answer, although it is correct answer but is it possible to use something like (((A FULLADDER B) FULLADDER C) FULLADDER D) as this way it can be easier to extend for n bits \$\endgroup\$ Commented Apr 7, 2017 at 20:11
  • \$\begingroup\$ @muhammadharis Generalized for odd and even numbers of bits? Or only even? \$\endgroup\$
    – jonk
    Commented Apr 7, 2017 at 20:27
  • \$\begingroup\$ Is it possible to generalize it only for even bits? \$\endgroup\$ Commented Apr 7, 2017 at 20:53
  • \$\begingroup\$ @muhammadharis I think it is generalizable, either way. It's just that you can take advantage of a bit of symmetry if it is even. \$\endgroup\$
    – jonk
    Commented Apr 7, 2017 at 21:00
  • \$\begingroup\$ I am confused because it looks like this solution is limited to 4 bits can you please explain how it can be generalised ? \$\endgroup\$ Commented Apr 7, 2017 at 21:41
