I was trying to solve a problem and I read that this code converts a number from hex to decimal I mean why . My idea is that div is just for division can somebody answer my questions that I left as comments
MOV A,#0FFH ;why do we need to do this MOV P1,A ;P1 as an INPUT MOV A,P1 ;Get data from P1 MOV B,#10 ;to convert from hex to decimal DIV AB ;that the question why does div used to do this conversion MOV R7,B ;does this put 10 in the register r7 MOV B,#10 DIV AB MOV R6,B ;it does also puts 10 in the register r6? MOV R5,A ;if A <10 (why does this do )
  • \$\begingroup\$ Could you please revert that edit? I had the formatting fixed. A picture is really not a good way to show your code. \$\endgroup\$
    – JRE
    Commented Apr 27, 2017 at 18:01
  • \$\begingroup\$ It'd help to state which assy lang. this is, but DIV AB appears to be integer dividing A by B, then putting the remainder in B. Thus, for FF you'd have R7=5, R6=5, and R5=2. \$\endgroup\$ Commented Apr 27, 2017 at 18:01
  • \$\begingroup\$ @JRE check edit log...y'all were having an edit war. \$\endgroup\$ Commented Apr 27, 2017 at 18:02
  • \$\begingroup\$ @RobhercKV5ROB: yeah, it was frustrating to fix the coding only for it to be mangled again. \$\endgroup\$
    – JRE
    Commented Apr 27, 2017 at 18:04
  • \$\begingroup\$ Tried to but it gets worse - I had it formatted nicely like MCS-51 assembly an hour or so ago. \$\endgroup\$
    – TonyM
    Commented Apr 27, 2017 at 19:38
Simple enough
A starts out being a number between zero and 255.
Lets say its FF i.e. 255..
Dividing by 10 gets you 25 in A and 5, the remainder, in B. That's the units value, so we save B to R7
Next we setup B with 10 again and divide the 25 by ten, and again store the remainder, this time in R6, as the tens digit.
What is left in A is the hundreds count, and we store that in R5.
So.. R5,6, and 7 now contain 2,5,5, the decimal equivalent of FF.
Here is a register trace if it helps..
  • \$\begingroup\$ Now I can agree with it & +1 ;) \$\endgroup\$ Commented Apr 27, 2017 at 18:06
