The LTC6200 impedance at 10MHz is 100x higher than your C11=0.1uF
Also it adds overshoot with even light capacitance load.
If your transient loads are significant then OK add a series RC after the unity gain OP Amp but as I would expect , you wont have significant load current so the R ratio is adequate to feed many comparators.
conclusion:
get rid of Op Amp.
Also, what is the tolerance on your need for 0.8V because the tolerance on your Vcc will drive the error on this. 2%?? 5%??
Generally if you need a good reference we use LDO's or bandgap zeners but if your Vcc is stable within 0.8V tolerance spec, just the R ratio is fine.
RC= 6k//0.1uF results in a few hundred Hz LPF whether you have an Op Amp or not but at least no overshoot on turn on. (which may not matter)
