Is there a method in Altium Designer where I can immediately create keepout lines on each edge of my board? My board shape has a complex design which is why I am looking for this method.
Go to Design -> Board Shape -> Create Primitives From Board Shape.
Then select what layer you want to create the primitives on and how thick you want the outline to be.
I don't have access to Altium at the moment so this is from memory. I use it all the time, though I use a separate mechanical layer specifically for the board outline (usually Mechanical Layer 6 renamed to "BOARD_OUTLINE").
What @DerStrom8 had suggested is correct. +1 to him. I'd like to elaborate a little.
- Go to Design → Board Shape → Create Primitives from Board Shape
- Pick layer and width in the dialog. Click OK.
Altium will create a track around the PCB. This isn't the keep-out yet. - Select this new track around the outline of the PCB.
- Go to Tolls → Convert → Convert Selected Primitives to Keepouts.
Now you have the keep-out around the board outline.
At the time of writing, I'm running Altium 20.1.10 .
added:
Related function in Altium: Board Outline Clearance .
This kind of clearance is faster to set up, because everything is defined in one rule. It creates a clearance with a constant width for all levels. It doesn't create an actual keep out object in the layout.
I used the board outline clearance rule for setting up the minimum clearance. Then I created keepouts on the board outline where I needed larger clearances.
