I have a question related to the amplifier circuit given in datasheet of 2SC1946A The circuit looks like this:
I need some info on the inductors used in the circuit. Following are my questions:
- What is the value of inductor L? Nothing is mentioned about L except L: Length 10mm. What does it mean?
- What is 1D (if D stands for Diameter)? Is it 1 mm diameter? Is it practical to wind a coil of 1 mm diameter with 1.5mm wire?
- How to wind 1/2 Turn of a coil? How should it look like?
- What is pitch of a coil. Is the gap between 2 parallel lines of winding wires?
- Should I change any component in this RF amplifier circuit if the input signal's frequency changes? Which Inductor and Capacitor duo forms the tank in this circuit, which is responsible for 150 MHz frequency?
