I am replacing all electrolytic capacitors in an old CB radio but can't find a local source for this capacitor. Is there another type I can use in its place? Does it have to be an electrolytic type? Thanks.
  • \$\begingroup\$ I see electrolytic 0.1µF caps starting at a dime apiece on mouser.com. \$\endgroup\$ Commented Mar 20, 2018 at 23:51
  • \$\begingroup\$ MLCC 0.1uF caps? \$\endgroup\$ Commented Mar 21, 2018 at 0:05
  • \$\begingroup\$ Electrolytic capacitors are almost never used for their electrolytic properties, only their capacitance. \$\endgroup\$ Commented Mar 21, 2018 at 0:08
  • \$\begingroup\$ Yeash...You can buy bags of 1,000 for a few dollars from Digikey/Mouser/Allied, etc. Stay with ceramic SMD for such low values. \$\endgroup\$
    – user105652
    Commented Mar 21, 2018 at 0:21
    \$\begingroup\$ "need" to be polarised?!? No such thing. \$\endgroup\$ Commented Mar 21, 2018 at 0:52
0.1 uF electrolytic caps are already or are almost obsolete
The lower cost solid Radial 0.1uF Tantalums have poor ESR (12~26 ohm)
Radial ceramics are fine. https://www.digikey.ca/product-detail/en/vishay-bc-components/K104K15X7RF53L2/BC3324-ND/2820506 $10 / 100pc
