I am trying to understand the theory of operation of a time domain reflectometer (TDR).
TDR is a time domain instrument with measurement the impedance versus the distance. If with a VNA one can measure s-parameters, then with TDR one measures impedance.
Why would TDR be called S-parameters measurement method?
Ok, if I know the impedances, then I can create matrix U= Z I, where Z and I are matrices. But How I can use TDR for S-parameter measurement?
I have found the some slides (enter link description here)
pictures from this pdf:
Q: What do they mean?
Those graphs are voltages at source terminal vs time.
The x-axis has two inflections, t=0 and t when wave reach the source again. The input is always Ei and the second value you see is the voltage at input terminal after reflecting.
Q: How to get these?
Deriving Zl=f(Eo,Ei)*Zo using reflection coefficient formula,
$$Γ=\frac{\ Z_L-Z_o}{\ Z_L+Z_o}$$
rearranging
$$Z_L=\frac{-(Γ+1)Z_o}{(Γ-1)}$$
and using
$$Γ=\frac{E_o}{E_i}$$
we have
$$Z_L=\frac{E_o+E_i}{E_i-E_o}Z_o$$
You can use this formula by substituting Ei=1 and Eo=-1/3 , 1/3, 0, 1. For example Eo=-1/3, $$Z_L=\frac{1}{2}Z_o$$
  • \$\begingroup\$ it makes sense. Actually I dont unerstand, for exp, the picture with Z goes to infinity, why the reflection and initial part are equal? \$\endgroup\$
    – user193562
    Commented Jul 17, 2018 at 16:12
