As derived from F = qvB sinθ, what is the unit of magnetic force, and why?
Edit: I mistakenly asked about magnetic field before. -- I'm asking the magnetic force.
It's a force, and that's always measured in Newtons.
B is not A/m, H is measured in A/m. B is measured in \$kg.s^{-2}.A^{-1}\$, base units, or the rather more electrically appropriate volt.seconds per m2, or Webers/m2.
We use sine or cosine depending on what we take to be the reference direction, whether it's along or normal to the conductor. The only difference is 90 degrees.
while I also don't understand why we use sine but not cosine
Because the actual formula is \$\vec{F}=q\vec{v}\times\vec{B}\$ and the vector cross product is defined so that the magnitidue of the cross product is 0 if the two vectors are parallel, and maximized when the two vectors are orthogonal.
What is the SI unit of magnetic field?
The units are tesla (T).
$$ 1\ {\rm T} = 1 \frac{\rm N \cdot s}{\rm C \cdot m},$$
or, in SI base units
$$ 1\ {\rm T} = 1 \frac{\rm kg}{\rm A \cdot s^2}.$$
In SI units, B is measured in teslas (symbol: T) and correspondingly ΦB (magnetic flux) is measured in webers (symbol: Wb) so that a flux density of 1 Wb/m2 is 1 tesla. The SI unit of tesla is equivalent to (newton. second)/(coulomb. metre). - Wikipedia
