Your requirements are a bit odd: you want zero output for -0.5 input, and basically 1V output for anything above zero (1u) input? What do you want to have in between? Linear interpolation? abrupt change in the middle? Hysteresis?
If you're using LTspice, then the best option readily available as a comparator is using the A-devices, in [Digital]
. The simplest is the AND
, or BUF
, with ref=<...>
being the threshold voltage, and with td
, tripdt
, and one of trise
+tfall
, or tau
, or rout
+cout
, being the temporal aids for the waveform. SCHMITT
triggers ar a bit more versatile in that they allow a threshold, vt
, and a hysteresis, vh
You could use a VCVS, or VCCS with proper termination (for better convergence, as per the manual), but table()
is a linear interpolation of points, bringing possible discontinuities, which means you risk time step too small
errors.
Here are the few presented options:
A1
is a BUF
, so it uses ref
as the reference and tau
for smooth RC output, A2
is AND
and uses the same ref
, with trise/tfall
for linear ramp output, A3
is a SCHMITT
(use DIFFSCHMITT
for differential input), so it uses vt
for threshold and vh
for hysteresis, while rout/cout
control the smooth RC output.
G1
+C1
form what you had in mind but, as you can see, it's limited: it needs a minor hysteresis, which needs to be very small compared to the swing, otherwise it linearly interpolates and you get the nice pink waveform, it has no complementary outputs (like the others before), and it needs a sort of a time constant at the output to help smooth out the discontinuities. All in all, you get two elements + two nodes, with drawbacks, compared to one element + two nodes[*] with improvements. Hardly a choice.
[*] If you're using the complementary outputs, then you have one more node, but then, for the G+C
version, you also need an inverter of some sort, so you add not only a node, but one more element (at least).
Having said these, for your solution it looks like you need a SCHMITT
gate, with vt=-0.25 vh=0.25
(vhigh
and vlow
are 1
and 0
by default), but this is assuming you want hysteresis. If you want linear interpolation, G+C
is the way to go. If you want an abrupt change in the middle, then go for BUF
or AND
, with ref=-0.25
