I've got a design in Altium and while routing, I moved a few resistors. They somehow accidentally got deleted and wouldn't undelete. I brought them back with an ECO, and placed them where I want them. Now, I have connection stringers going to their old location, and can't seem to get rid of them. Anyone else come across this?PCB
Edit: Design rule check does not fix this.
  • \$\begingroup\$ I have had this in the past; I seem to recall that running a design rules check from within the PCB environment fixed it. \$\endgroup\$ Aug 30, 2019 at 14:44
  • \$\begingroup\$ @PeterSmith That did not work - tried already. \$\endgroup\$ Aug 30, 2019 at 14:49
  • \$\begingroup\$ Another reason that this can happen is that if there is a tiny piece of copper assigned (assuming you had routed them previously) which you will need to significantly zoom in on to actually see, it retains the net ID. \$\endgroup\$ Aug 30, 2019 at 14:50
  • \$\begingroup\$ @PeterSmith - had the same thought, tried that too. Nothing there. Selected the whole area and deleted it... Still persists. \$\endgroup\$ Aug 30, 2019 at 14:50
  • \$\begingroup\$ Are you sure you have all layers turned on? \$\endgroup\$
    – Axis
    Aug 30, 2019 at 15:31
Found the problem. Ran the command Design > Clean Net List, then Tools > Reset Error Markers - that cleared up the problem.
