this is my first question on the site, so please let me know if there's something I can do to write it more helpfully.
The Problem: I'm building a small radio. At the output of my mixer, I need to build a narrowband filter at 455 kHz, and also convert the signal from double-ended to single-ended.
My Solution: Build a resonant LC filter that feeds a balun transformer. I first tried a shunt LC tank, which worked okay. But I realized that the filter was heavily dependent on exact L and C values, so I decided to try tuning it with a varactor (which would allow me to use L's and C's with looser tolerances). Unfortunately, varactors are very small, and the parallel inductance of my transformer placed a limit on how small I could make my capacitors.
So I decided to try out a series LC. Unfortunately, this put the mixer's \$R_{out}\$ in series with my inductor, which destroyed my Q. I was about to give up when I read this SE answer, which seemed to suggest that I could match a high impedance by adding a shunt capacitor.
On a whim, I threw in a 100nF cap... and it worked perfectly! My Q and insertion loss are both much better. But... why?
Here's my (simplified) circuit:
V3+R3 is my source, C5+L3 is my filter (L3 has \$R_{series}\$ = 250 mOhms), and L4 is my transformer ( \$R_{series}\$ = 75 mOhms).
Learning is the goal of this project, so any advice / additional resources would be welcome. Thanks!
