Newbie here. I bought a couple BC547B transistors to build some logic gates. I'm using a breadboard which is connected to the 3.3V and ground from my UNO Elegoo R3 controller.
I connected an LED to the emitter of the transistor. It lit up once I connect the power supply with the base pin, even though the collector was disconnected. I have followed this other thread and connected a high resistor (tried 100K and 1M) between base and emitter, which makes the LED glow really dim. Once I connected the collector it lighted up very bright again.
My question is: How can I fix this issue? Ideally I want to LED to not light up at all unless there is current on the collector. I already made sure that the transistor pins are two lanes apart each, but that did not help.
    \$\begingroup\$ Draw a schematic. \$\endgroup\$
    Jul 19, 2020 at 14:16
  • \$\begingroup\$ in addition to the schematic, as Andy mentions, you can also include a picture of your breadboard. The schematic does not have to be a real working (simulation) schematic, we just need to see some sort of drawing. Hand drawing is often also good. \$\endgroup\$
    – P2000
    Jul 19, 2020 at 14:37
Move the LED to be in the collector circuit (with the appropriate series current limiting resistor) and connect the BC547 emitter to ground/0 volts. Feed the base via a 1 to 10 kohm series resistor.
As you currently have it connected, the base-emitter junction acts like a forward biased diode and will supply the LED with current via the base. With the above proposal this won't happen.
