In IC design, corner analysis is performed to study the operation of the ICs under extreme conditions and Monte Carlo analysis is performed to ensure the mismatch is within the tolerance.
However, can the results given by the corner analysis and the Monte Carlo analysis be different? For exapmle, in a TT corner @27C, the output voltage is, say, 1.8V. But the mean output voltage given by the Monte Carlo analysis @ 27C is only 1.6V even if the corner analysis and the Monte Carlo analysis are based on the same set of design parameters (such as L and W).
Also if this happens, what would be the solution? Would different sets of parameters be used for the corner analysis and the Monte Carlo analysis?
Thanks
