All the other answers have adequately covered your question. I'm going to add a reminder that audio amplifiers are not precision equipment.
Your amplifier will be able to faithfully reproduce the signal you give it, as long as you keep your signal within the input limits of the amplifier and as long as you don't "crank up the volume" to the point that the output clips (distorts.)
If the output level is in any way critical to your experiment, then you will need to measure the output level. Your output level is related to the input level by the amplification (gain) of your amplifier, and by the setting of the volume control knob.
The volume control isn't calibrated in any way - you can't rely on it for absolutely reproducible results.
Since you don't (can't) say what the experiment is about, no one can even begin to guess how critical the output power is.
If it's critical, measure it.
As a value for repeating your own steps, the output voltage (peak to peak or RMS) would be a good starting point. You'll need either an oscilloscope or an AC voltmeter to measure it. If you use an AC voltmeter, you'll need one that covers the entire audio range. Common hardware store voltmeters cover just the typical household AC line frequencies (50 or 60 Hz.) AC voltmeters that cover up to 20kHz can be expensive.
For whatever paper you write about your results, you may need to include to actual power into the coil, and maybe the waveform as actually fed into the coil.
