I've fried the controller on this PCB when by accident connected 24V supply in reverse polarity. The PCB includes a SS34 schottky on a positive side. However the controller still got damaged (completely dead).
I already got a replacement controller and will replace it on the board. My question is -- why the controller got damaged even though there is a supposed reverse polarity protection and how it should be protected properly?
Notes:
- I am not the designer of linked board
- The board includes 3 separate power inputs. 2 were connected correctly, 1 was incorrect (reverse polarity), which should be causing short through the ground I presume?
- The SD card that was inserted into the slot also dead, but nothing else appears to be damaged
