I don't know the basic functionality of the circuit and I need a complete description of every component.
1\$\begingroup\$ Have you Google "how do modulators work"? \$\endgroup\$– PasserbyCommented Apr 7, 2021 at 6:30
\$\begingroup\$ I haven't, thank for the keyword \$\endgroup\$– MegakawaCommented Apr 7, 2021 at 6:35
\$\begingroup\$ Could you help me explain what Saw-433 do in this circuit ? Does it produce 433mhz carrier wave or modulated the signal ? \$\endgroup\$– MegakawaCommented Apr 7, 2021 at 6:51
1 Answer
That's the simplest RF transmitter at 433.92 MHz that one can design.
That's the lowest cost RF transmitter ever.
That's an on-off RF transmitter.
T1, R1, C1, C3 and the SAW filter are the oscillator.
R2 and T2 allow the external digital command "DATA" to turn on and off the oscillator.
C2 is a DC blocking capacitor. You want to send AC signals only to the antenna.
L2 is an RF choke that allows the DC bias current only to arrive to the oscillator. It's a filter of AC currents.
When DATA is 3 V or 5 V then the oscillator starts oscillating and the antenna transmits RF energy in the air.
When DATA is 0 V then the oscillator stops oscillating.
SAW filter selectivity:
The selectivity of the of the oscillator is SAW filter's responsibility.
If the SAW filter is selective in frequency then the oscillator will send antenna narrow band RF signals.
If the SAW filteris selective then the RF energy sent to the antenna is well concentrated around the 433.92 MHz RF channel.
If energy is well concentrated around the 433.92 MHz RF channel, then the receiver is happy because its RF sensitivity and RF selectivity go up.
That circuit can be simulated by LT Spice free simulator.
One need to find an appropriate SAW filter at 433.92 MHz device model for LT Spice.
This in an interesting article about a spice model for a SAW device:
https://sbmicro.org.br/sforum-eventos/sforum2001/abarbosa.pdf
This in an interesting book about SAW filters:
"Understanding Surface Acoustic Wave (SAW) Devices for Mobile and Wireless Applications and Design Techniques"
by Colin K. Campbell
The BJT T1 must have a cut-off frequency significantly higher than 433 MHz.
NEC's BJT 2SC3357 is an NPN silicon epitaxial transistor designed for low noise amplifier at VHF, UHF and CATV band.
2SC3357 is a low-noise and high-gain bipolar transistor.
Features at bias point 1: Vce = 10 V - Ic = 7 mA - Zout = 50 Ω
NF = 1.1 dB - Ga = 8.0 dB - f = 1.0 GHz
Features at bias point 2: Vce = 10 V - Ic = 40 mA - Zout = 50 Ω
NF = 1.8 dB - Ga = 9.0 dB - f = 1.0 GHz
Ga = gain, NF = Noise figure
\$\begingroup\$ It took me and my team a lot of time to study this, thanks again for your help ! \$\endgroup\$– MegakawaCommented Apr 7, 2021 at 7:53
\$\begingroup\$ You can simulate that circuit by LT Spice free simulator. You will need to find a SAW device model for LT Spice. \$\endgroup\$ Commented Apr 7, 2021 at 8:13
1\$\begingroup\$ Notably the SAW filter has to be narrow < 1MHz bandwidth. And you also have to restrict the power to a few mW. Otherwise it will fail to meet the requirements of the band. \$\endgroup\$– LundinCommented Apr 9, 2021 at 6:26
