I pulled some LM13700 OTAs from an old board and tested them. All voltages, currents, and resistances were measured. I had the expected (approximate) voltage gain using the equation \$ A=(R_2/(R_1+R_2 ))*g_m*R_L \$ where gm equals \$ 19.2*Iabc \$.
The problem begins when I use the linearizing diode on pins 2 or 15. The gain goes down substantially, the higher the current on these pins, the lower the output. I have used Marston’s equation from the old Nuts and Volts article, \$ I_{out}=2*I_S*(I_{bias}/I_D ) \$ but the result are way off.
Does anyone know of a better way to calculate gain in an LM13700 when the linearizing diodes are used?
UPDATE - I got a couple of new LM13700s and got the same results.
