I am a beginner in electronics so please bear with me if this question seems stupid for you.
I have a circuit that I want to modify at certain points. All in all there are 8 modify points in the circuit and 8 modifications that short these points or place a capacitor in between them. To put it in a nutshell I need to toggle 8 data lines. I thought there were 8-pole 2-throw switches. Unfortunately I could find such switches. I read that a multiplexer would be a good idea.
However I never worked with them. I wondered if this is the right way:
Again sorry if this sketch seems hideous to you. As you can see every 4051 MUX has a modified circuit as an output. So I need eight multiplexers for every modification point. Every multiplexer is controlled by a microcontroller like an arduino. The microcontroller establishes the control sequence based on the output of a 74HC165 shift register. This shift register generates its output by checking which switch is closed.
I couldn't verify this schematic because I don't have the multiplexers yet. Could this work?
