I'm trying to understand how op-amp works, but I'm bit stumped by its open loop behavior.
In different sources I found that \$v_u=A ⋅ v_d\$, where \$v_d=v_+ - v_-\$; since \$A=∞\$, the explanations I found concludes that \$v_d=\frac{v_u}{A}=0\$, with no limitation to closed loop (which I found only in Wikipedia: "In a closed loop the output attempts to do whatever is necessary to make the voltage difference between the inputs zero", https://en.wikipedia.org/wiki/Operational_amplifier#Ideal_op_amps).
I understand why \$v_d=0\$ is true in closed loop, but I'm not sure why it is in open loop.
On an MIT paper I found that (note: I changed \$V_i\$ to \$v_d\$ and \$V_o\$ to \$v_u\$ to have the same notation as above):
Note that when using the ideal op-amp rules we should remember that they are limits and so we must perform our analysis by considering them as limits. For example if we consider the equation
\$v_u=Av_d ⇒ v_d=\frac{v_d}{A}\$
Which in turn implies that \$v_d → 0\$ as \$A → ∞\$. However, this does not mean that \$v_u → 0\$ but rather that as \$A → ∞\$, \$v_d → 0\$ in such a way that their product \$Av_d=v_u ≠ 0\$.
I get why "tends to 0" is different to "equals zero", but "as \$A → ∞\$, \$v_d → 0\$ in such a way that their product \$Av_d=v_u ≠ 0\$" sounds like a closed loop behavior, since it states that the input changes according to the output.
Moreover, also with the idea that \$v_d\$ takes a close-to-zero value so that \$v_u\$ gets to a non-zero value, \$v_d=v_+ - v_-\$ is an input, so I can give them whatever value I want; if I use an open loop op-amp as comparator, \$v_+\$ and \$v_-\$ can have significantly different values, so \$v_d=v_+ - v_-\$ wouldn't be equal (or tending) to zero.
I understand I'm missing something in my basic understanding of how an op-amp works, but despite looking on several sources I wasn't able to find what I'm missing.
