I would like to replace the cable attached to this connector but it seems to have some kind of special locking mechanism on the top.
It has 12 poles with a standard spacing between the pins of 2.54 mm and looks Molex-like but does not seem to belong to the usual suspects.
Connector, all dimensions in mm
How can identify this connector and purchase a suitable replacement?
  • \$\begingroup\$ duckduckgo.com/?q=keyed+pin+header&iax=images&ia=images \$\endgroup\$
    – jsotola
    Commented Feb 9, 2022 at 22:55
  • \$\begingroup\$ google.com/… \$\endgroup\$
    – D.A.S.
    Commented Feb 10, 2022 at 1:46
  • \$\begingroup\$ @TonyStewartEE75: Thank you, that is exactly the one. Do you want to convert your comment into an answer? \$\endgroup\$
    – Alexander
    Commented Feb 10, 2022 at 21:42
    \$\begingroup\$ Molex-like Well, as it turns our, it is a Molex connector. \$\endgroup\$ Commented Feb 12, 2022 at 16:59
It is an industry standard connector, an "unshrouded rectangular connector, female housing, with polarizing key". The one you drew is made by Molex (P/N SL 70450.
Molex SL 70450 {Credit: Digikey}
Amphenol ICC makes a similar one (the polarizing key is slightly different) (P/N 69176-012LF).
