I am getting different bandwidth measurements from my breadboard and PCB (for the same circuit with exact same component values). The cut-off frequency I measure on the breadboard is slightly higher than that of the PCB. I though breadboards have a higher parasitic capacitance due to their area. But then shouldn't the breadboard bandwidth be lower than that of the PCB? Is there a comparison I can make between breadboard and PCB parasitic capacitances? Or is there something else causing this difference?
