The device I'm designing consists of an STM32F405, a few 3V peripherals, and a few 5V peripherals. The device is is powered off of a 12700 Li-ion battery. The first regulator is a buck/boost that is directly connected to the input of the battery and feeds the STM, the idea is that the STM is always powered and is in deep sleep until a button wakes it up. There is then a 5V boost switching regulator and another 3V LDO that both have their enables on the STM GPIO, these two are in series so the 5V has to be enabled first in order to turn on the 3V LDO. This setup is niche and I think there is something to learn from the problems that I am having. Keep in mind the STM powered by the first 3V regulator is pulling up all of the I2C lines of the peripheral that is powered on a separate 3V bus.
The problem I'm seeing is that the system 3V LDO output without being enabled has a floating voltage on its output. Is this because the isolated regulators share a common ground, and are technically being used on the same devices because of the I2C pull-ups? Also, with the system 3V regulator not populated and 5V is applied to PACK+ I get 5V if I measure between PACK+ and 3V, why is it grounding through 3V?
STM
POWER
  • \$\begingroup\$ What's niche to you may be daily life to someone else. The first problem is missing VDDA connection so the MCU should not even start running. \$\endgroup\$
    – Justme
    Commented Aug 25, 2022 at 17:04
  • \$\begingroup\$ Yeah I know thats fixed already \$\endgroup\$ Commented Aug 25, 2022 at 17:50
It will power the I2C devices through the ESD protection diodes on the inputs.
It would be better to tie the I2C pullups to VCC of the I2C devices, so they are only active when the devices are powered.
If the I2C peripheral objects to this, you can always turn it off when it is not used.
    \$\begingroup\$ This answer is correct; I2C pull-ups should be to the switched chip supplies. To see if the I2C pins are the only problematic pins, set them as open-drain GPIO pins that pull low, and see if there still is leakage via other pins or pull-ups. \$\endgroup\$
    – Justme
    Commented Aug 25, 2022 at 18:09
