I need to identify a replacement for this 12 pin flat cable connector. I don't seem to be able to find the right google terms to come up with a useful result. A 12 pin AWM 2896 cable plugs into this. It seems to be a 2 row package (pins are staggered in two rows), and if I understand pitch
correctly, a ~1.26mm pitch.
Add a comment
1 Answer
It's an FFC socket, LIF (Low Insertion Force), straight, thru-hole, 1.25 mm pitch.
{source: Digikey}
Made by:
- MANUF. - SERIES
- Adam Tech - PCB 1.25mm
- JST - FE
- Molex - 52044
- Molex - 52045
- TE - 84533
- TE - 84534
I found it using my connector identification utility
