Looking for a rectifier made up from an inductor instead of a capacitor, I came to this question.
The circuits on the figure are dual each other, in the Thévenin Norton sense, with capacitor voltage and inductor current, the results are the same.
After adding an Ideal Diode, I am unable to find some close analogy of that dual.
Considering an Ideal Diode is only a switching device, though non linear, I could assume that dual could exist. Anybody have a good estimate on how to find that dual?
If you consider to get a fair analogy between the two circuits you may think to replace the diode by a constant-current diode since the characteristics are equivalent when we interchange voltage with current:
and hence replacing the voltage source with a current source:
Think also to consider components in parallel instead of serial.
  • \$\begingroup\$ I figured that the Dual of the Voltage Source with an Ideal Diode in series should be a Current Source with an Ideal Diode in parallel. For an Ideal Diode I think it would not matter. For a Less Than Ideal Diode, this would be the solution. \$\endgroup\$
    – Brethlosze
    Commented Jan 17, 2023 at 17:23
