How does one convert drift in ppm/°C to V/°C?
Assume a 5 V voltage reference has an output voltage drift of 12 ppm/°C.
What is the output voltage drift in volts for a target temperature of 85°C?
1\$\begingroup\$ 60 micro-volts per degree C \$\endgroup\$– user319836Commented Feb 1, 2023 at 15:39
1\$\begingroup\$ "ppm" means millionth of the full value \$\endgroup\$– tobaltCommented Feb 1, 2023 at 15:46
Add a comment
1 Answer
Depends on how they specify it. Link to datasheet please.
1 ppm of 5 V is 5 μV.
If your base temperature in the datasheet is 25 °C then (85°C-25°C) × 12 ppm/°C × 5 V = 3600 μV = 3.6 mV.
