I am still fairly new to DC/DC converters and was wondering how to generate negative output supply with a positive input supply. I don't know what the general requirements and limitations are but here's what I had in mind based on this application note:
Now, TI's Power Designer doesn't allow applying a negative output voltage for the TPS563300 and for obvious reasons I won't find the TPS563300 in the LTSpice library. Analog Devices, however, has the LTC3336 in their library and applying the topology shown above works at least according to simulations. The LTC3336, however, has a maximum input voltage of 16.5 V and going from +12 V down to -5 V spans 17 V, so I think this product is a no-go.
What are the criteria for allowing the generation of a negative supply from a positive input? I think one of them is the maximum input voltage with respect to the converter IC's ground. Is another one that the switching output (SW) has to be a half-bridge? From the simulation above it seems I need to take measures to avoid a positive supply during startup. What other things do I need to bear in mind or watch out for?
For completeness sake: I want to convert from +12 V to -5 V for a maximum current draw of 100 mA. Even though LDOs are cheaper alternatives where I don't have to go through the extra effort of EMI filtering, I want to avoid dissipating the excessive heat.
