So I'm working on a 2 month design project with the following description
I'm trying to exhaust the possible ways to design this without using microcontrollers or ready-made chips. Some of the problems I'm experiencing is:
How to turn on a buzzer after the counter reaches 99
How to alternately display the temperature and the count every ten seconds on the same set of LEDs
The count will simply come in the form of a high voltage of approximately 5 V.
The temperature will come in the form of a digital signal. I need only display on two 7-segment/8-segment displays.
A power of 5 volts for the counter IC is already given to me viz. 5 V.
I came up with the following block diagram so far just to give me an rough idea:
