I want to implement an active analog high pass filter, which behaves as a high pass filter implemented by a capacitance, an inductance and a resistor in the following way:
Which gives the follwing transfer function:
$$G_{hp} = \frac{CLs^2+RCs}{CLs^2+CRs+1}$$
Usually second order high pass filters are build up by Sallen-Key elements.
But the transfer function of these filters is given by $$G_{hp2}=\frac{\frac{s}{\omega_g}^2}{\frac{s}{\omega_g}^2+s\cdot a\cdot\frac{s}{\omega_g}+1}$$ $$\omega_g=\frac{1}{RC}$$
In this transfer function there is only a conjugated complex zeros. But what I want to have is a zero at 0 and R/L.
Does some one know a circuit, which will give me an active filter, which is build up by an op-amp, capacitors and resistors, which behaves as the LCR filter?
