I am trying to measure the output impedance of an inverting op-amp.
I tried it by connecting a variable resistor to the output. My objective was to use that resistor and output impedance as a voltage divider (like in the figure), measure that divider voltage, and calculate the output impedance.
The thing is, for low resistor values like 100 ohm (I used that value because the data sheet says that the output impedance of 741 IC is around 75 ohm, so for get good accuracy of the measurement I used 100ohm) the output gets saturated at some level (around 2 V) before reaching its maximum point (like in the figure.) I guess it happened because of the output voltage swing (correct me if I am wrong.) Can you suggest a method to measure the output impedance or to avoid the output voltage swing?
  • \$\begingroup\$ Your output is severely clipping because you are overloading the opamp's output. The datasheet says that the maximum output current of an antique (55 years old) 741 opamp is only 25mA so you must reduce the signal levels to avoid clipping. \$\endgroup\$
    – Audioguru
    Commented Jun 11, 2023 at 16:09
The closed loop output impedance will be quite low -- equal to the open loop output impedance divided by the loop gain.
If you want to measure the output impedance at DC, you don't need an input V source -- apply a small DC input signal - about ½ V will avoid saturation.
Then measure VOUT with no load, and again with R3 connected. The output impedance is the change in voltage divided by the load current (VOUT/R3)
To measure the AC output impedance, again apply a small (say 0.5 V peak) sinusoid and measure VOUT with and without the load -- the difference is the change in VOUT divided by the load current. Note that this is a complex quantity, so (mathematically) you'll need to take the complex values into account. If you are performing a lab measurement, this can be difficult to do accurately.
  • \$\begingroup\$ It is correct -- voltage feedback REDUCES output impedance of the system. Higher loop gain reduces output impedance (in the extreme, 0 loop gain (i.e. no feedback) leaves ZOUT at the original value of the opamp) \$\endgroup\$
    – jp314
    Commented Jun 11, 2023 at 0:30
  • \$\begingroup\$ @user107063 explain yourself. More loop gain means less output impedance when using shunt output feedback. \$\endgroup\$
    – Designalog
    Commented Jun 11, 2023 at 21:21
  • \$\begingroup\$ @ErnestoG Termonilogy error on my part. I took "loop gain" for "closed loop gain" but that's totally something else. After looking "loop gain" up, the correct answer would likely be "open loop impedance divided by (1-loop gain)" (since the open loop has a loop gain of 0 if I understand correctly and loop gain is usually negative). Deleting my first comment. \$\endgroup\$
    – user107063
    Commented Jun 11, 2023 at 21:48
If we artificially introduce an impedance in series with an op-amp's output, and we take feedback from and measure the output after that resistance, we will see how negative feedback compensates for this extra impedance, and produces the correct output regardless:
The outputs from these op-amps are considered to be OUTa and OUTb, and output resistance is being modelled by ROUTa and ROUTb. Remembering that since these resistances are representing impedance inside the IC, their left ends are usually inaccessible from outside, but with this model I am able to show the potential at this "hidden" node, as measured by VM1a and VM1b.
I have set gain to \$-\frac{10k}{1k}=-10\$, so that with an input of -1V we would expect the outputs of an unmodified op-amp to be +10V. You might think that the presence of ROUT would cause the output to deviate significantly from the ideal of +10V, but remarkably, even though we have increased the output impedance of the op-amps significantly, both circuits are still producing exactly +10V at their surrogate outputs, as shown by VM2.
This is because of negative feedback, which causes the op-amp to adjust its output to whatever value is necessary to equalise the potentials at its inverting and non-inverting inputs. It doesn't matter how much current you draw from the output, or how much voltage is dropped across ROUT, the op-amp still does whatever it has to do to bring those to inputs to the same potential.
You can see how the op-amp compensates for the voltage drop across ROUT, by raising its output slightly higher than the required 10V output. Notice how "internally" the op-amps are producing slightly more than 10V, shown on VM1.
There's more. If I place a load on the surrogate output OUTb, say a 1kΩ resistor which would draw \$\frac{10V}{1k\Omega}=10mA\$, look what happens to the potential of OUTb:
Absolutely nothing happens. Somehow, the output is still exactly +10V, in spite of there being 10mA more current flowing through ROUTb. Remember, all the op-amp is doing here is adjusting its output to ensure that its two inputs have the same potential. Considering that the only way that can this condition of equality can be true, is if node OUTb is at exactly +10V, this makes sense. If node OUTb was lower, then the op-amp would act to raise the output, until that equilibrium is achieved.
You can see on VM1b that this is exactly what happened. The voltage there has risen to +11.1V, a rise of exactly enough to bring OUTb to +10V, which is exactly the potential necessary to equalise the op-amp's two inputs. All this happens in spite of our attempt to "weaken" the op-amp with ROUT, and to demand more current with RLOAD. The response of the op-amp (due to negative feedback) is simply to "pull harder"!
To get back to your question, how to measure the amplifier's output impedance, perhaps you don't need to. We have increased current output by adding RLOAD, and that had no effect on output voltage. That's another way of saying that output impedance is zero.
In practice, it is only near zero, because op-amps are never ideal. If you want to measure that near-zero output impedance, you'll need some pretty precise measurement equipment, because any change in output potential as current varies, is going to be tiny.
If you are interested in measuring the output impedance of the op-amp, then you must do so with the loop open, with no negative feedback. This requires you to bias the two inputs very very precisely, to get the output somewhere near the mid-point of the power supply potentials, and then load the output while monitoring output potential change. This is hard to do, as any temperature change or even the slightest input potential change will cause the output to quickly diverge from where you initially put it.
