This is a simple question. I want the new Iphone EarPod to work with Samsung/Nokia phones. I tried to use the headphone to Samsung phones. Here is the result
Here is the Universal 4-pole Cell Phone headset pinout, the one which Samsung/Nokia make. enter image description here
Now the question is:
  1. How can I make a converter/adapter for the pin to work well with Iphone EarPad? (I don't want to cut the wire and check which wire works for which function)
  2. Is there a way to make a simple circuit within the connector which makes the impedance match?
I'm really not in the electrical engineering field, so please consider me as an absolute beginner.
I don't care whether the play/pause/vol.up/vol.down functions works or not. I'll consider it as an added advantage if it is possible. :) But I need mic & the speakers to work well.
    \$\begingroup\$ Essentially, some Android phones have a L/R/Mic/Gnd setup while the iphone has L/R/Gnd/Mic. Switch those two pins around (3 and 4) and you should get the mic and the play/stop button to work. The Next/Prev button or volume control are not as simple. \$\endgroup\$
    – Passerby
    Commented May 9, 2013 at 3:40
  • \$\begingroup\$ Thank you, I'll try it.. What about the impedance matching? \$\endgroup\$
    – Sen Jacob
    Commented May 9, 2013 at 3:54
  • \$\begingroup\$ Related Qn : How to wire sennheiser headphones to an iphone headphone cable? \$\endgroup\$
    – Sen Jacob
    Commented May 9, 2013 at 4:35
  • \$\begingroup\$ Related Qn : Electronic aspects of iPhone 3.5mm audio output. \$\endgroup\$
    – Sen Jacob
    \$\begingroup\$ Ignore it. As long as it's close enough (you're not trying to drive 4Ω speakers or 600Ω headphones), you will be fine. You might not get the full volume range, but sometimes those volume ranges can cause permanent hearing damage anyway. \$\endgroup\$
    – Passerby
    Commented May 9, 2013 at 5:45
Essentially, some Android phones have a L/R/Mic/Gnd setup while the iphone has L/R/Gnd/Mic. Switch those two pins around (3 and 4) and you should get the mic and the play/stop button to work. The Next/Prev button or volume control are not as simple. – Passerby May 9 '13 at 3:40
