I am reading about working with virtual ground and generating negative voltage. I am trying to power a differential op amp circuit, and I expect some of these differences to result in a Vout that is negative. Because of this, I wanted to bias my op amp with +5V and -5V.
I only have a positive voltage source, and I am using TinkerCAD to simulate this. I read that I can use things like charge pumps, but I was wondering if it would be possible to implement a virtual ground as a reference ground and anything below this reference point would be negative. So this would make actual ground (0V), be interpreted as -5V, if my virtual ground was 5V and my power supply was 10V.
In the first picture, I take two power supplies and put them in series with each other to establish a virtual ground. This seemed to work well, since 5V - 3.3V = 1.7V in the Vout as expected, but I wanted to try to do this with only one power supply
In this second picture, I created a virtual ground (5V) using a voltage divider and two capacitors in parallel (schematic I found online is attached below). I then set the ground of another breadboard to be this new reference, and it seems like the rails are measuring +/-5V as expected.
However, when I connect two voltage sources to then use the differential amplifier (3.3V and 5V), I get a change in voltage readings across all of the rails and I am not sure why, I'd like them to be stable.
I am wondering if someone can help me figure out the issue, or guide me on what steps I should take to troubleshoot. I appreciate any help!
If helpful, this is the differential op amp circuit I was trying to implement: Referenced from another stackexchange post: How to Calculate Op-Amp Level Shift for differential amp and gain of 2
And this is the capacitor and resistors voltage divider circuit I was following online:
Referenced from learnelectronics on YouTube at time [2:56]: https://www.youtube.com/watch?v=5CaPmKfBhDk&ab_channel=learnelectronics
