What is the required pad diameter for the following part ?
Maybe its late and I'm just not seeing ? The recommended PCB hole layout usually contains this information but I just don't see it.
Based on @PeterJ comment, see http://portal.fciconnect.com/Comergent//fci/drawing/bsa201572001.pdf for the through hole pad dimensions. 0.7mm to 0.65mm after through hole plating.
