This was a challenge problem that my instructor gave. Here is what a class AB amplifier looks like:
I've looked everywhere to find out about internal impedance but I got nothing. This is the problem I'm trying to solve:
Determine the maximum peak to peak signal that can be applied to a amplifier and the efficiency rating or nstage for the amp. Assume the amp is driven by a sine source and has an internal impedance of 600 ohms.
Given:
- \$\text{hfe} = \text{hFE} = 100\$
- \$V_{be} = 0.7\$
- \$E_s = 32.093~V_{p-p}\$ at 1 kHz
- \$R_L = 8~\Omega\$
- \$R_1 = R_2 = 1~k\Omega\$
I've tried all that I've been taught so far. I took the internal impedance as \$Z_{input}\$. Then, I used \$Z_{input}\$ and \$E_s\$ to find \$V_{in}\$, since \$V_{in} = V_{out}\$ is the voltage at the load. Finally, I used that answer to find the efficiency as \$P_L / P_{dc} \cdot 100 \$.
I calculated an efficiency over 200%, which must be wrong. What am I doing wrong?
