library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
--use IEEE.STD_LOGIC_UNSIGNED.ALL;
use ieee.std_logic_signed.all;
entity fifo is
port ( clk : in std_logic;
read_data : in std_logic; --enable read,should be '0' when not in use.
insert : in std_logic; --enable write,should be '0' when not in use.
delete : in std_logic;
datain : in std_logic_vector (7 downto 0); --input data
dataout : out std_logic_vector(7 downto 0); --output data
empty : out std_logic := '1'; --set as '1' when the queue is empty
full : out std_logic := '0'; --set as '1' when the queue is full
no_insert : out std_logic;
no_delete : out std_logic
end fifo;
architecture Behavioral of fifo is
type memory_type is array (0 to 255) of std_logic_vector(7 downto 0);
signal memory : memory_type :=(others => (others => '0')); --memory for queue.
signal rp,wp,tmp_ptr : std_logic_vector(7 downto 0) :="00000000"; --read and write pointers.
signal isfull : std_logic := '0';
signal isempty : std_logic := '1';
begin
--dataout <= "00000000";
process(clk)
begin
-- Reading Process
-- Read when not empty
-- empty when Write_ptr = Read_ptr
-- increment as 0 1 2....255 0 1 2....255
-- If Last_wrt is high set low Last_rd,
-- overwrite Last_rd as high if actually reading take place
if(clk'event and clk='1' and read_data ='1') then --read the tail of FIFO
--if(isempty = '1') then
-- dataout <= "00000000";
--else
dataout <= memory(conv_integer(rp));
--end if;
end if;
if(clk'event and clk='1' and insert ='1') then --insert on the top/head of FIFO
--if(isfull = '1') then
--no_insert <= '1 ;
--else
no_insert <= '0';
memory(conv_integer(wp)) <= datain;
dataout <= datain;
--if(wp = "11111111") then
-- wp <= "00000000";
--else
-- wp <= wp + 1;
--end if;
--end if;
--if(wp = rp) then
-- full <= '1';
-- isfull <= '1';
-- else
-- full <= '0';
-- isfull <= '0';
--end if;
end if;
if(clk'event and clk='1' and delete ='1') then --pop/delete the tail of FIFO
-- no_delete <='1';
--else
no_delete <= '0';
-- if(rp = "11111111") then
-- rp <= "00000000";
-- else
rp <= rp + 1;
-- end if;
-- if(rp = wp) then
-- empty <= '1';
-- isempty <= '1';
-- else
-- empty <= '0';
-- isempty <= '0';
-- end if;
--end if;
end if;
if(rp = "11111111") then --resetting read pointer.
rp <= "00000000";
end if;
if(wp = "11111111") then --resetting read pointer.
wp <= "00000000";
end if;
if(wp = rp and insert = '1') then --checking whether queue is full or not
full <='1';
else
full <='0';
end if;
if(wp = rp and delete = '1') then --checking whether queue is empty or not
empty <='1';
else
empty <='0';
end if;
end process;
end Behavioral;
In the above vhdl code for FIFO I am not actually getting the write testbench simulation. Even though the FIFO buffer is not full then also full becomes equal to 1. Can some1 please help me sort out the error ?
when the process(clk) is run everytime on the clk tick then what exactly happens .... are all the ifs called simultaneously ?I mean all the different functions in the process(clk) block rum at the same time in parallel ?
